Activity › Forums › Adobe After Effects › Expression Comp Duration
  • Expression Comp Duration
    Posted by Dominik Schulz on November 26, 2012 at 10:08 am
    Hey,
    I try to create a countdown in after effects. Everything works.
    Now to make it easier I need an expression to use the duration of the comp (mm:ss) as the start of the countdown.
    When i use “time” my countdown starts at 00:00.
    For example: The duration of my comp is 0:30:24:00
    Now i want to start at 30:24 down to 00:00 with an expression.
    Thank you!
    John Cuevas replied 13 years, 10 months ago 2 Members · 1 Reply
  • John Cuevas
    November 26, 2012 at 12:50 pm
    Check out this thread: https://forums.creativecow.net/thread/227/10693#21828
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
