Activity Forums Adobe After Effects Expressions expression breakdown
  • expression breakdown
    Posted by Dom Brooks on May 17, 2018 at 9:31 am
    Would anyone be kind enough to explain to me how this expression works?
    I’m pretty new with expressions but have a laymans understanding.
    I’m trying to learn and want to understand why certain lines effect certain parameters.
    This is an expression by JR canest that allows a shape layer to retain it’s original scale whilst attached to a parent object’s scale value.
    i understand the first two lines are establishing parameters s being the scale of the object in question and ps establishing the parents scale value
    then i get a little lost.
    any help would be great
    s=[];
    ps=parent.transform.scale.value;
    for(i=0;i<ps.length;i++){
    s[i]=value[i]*100/ps[i];
    s
    Sam Catt replied 8 years, 3 months ago 2 Members · 1 Reply
  • Sam Catt
    May 17, 2018 at 12:17 pm
    so without knowing what these are exactly or how they are effecting the object I can’t tell you quite the results. But, I can explain whats going on.
    so
    s = []; //this is setting a variable for s, to be equal to an iterator
    ps=parent.transform.scale.value; //this sets this layers parents scale value to ps
    for(i=0; i < ps.length; i++){
    this is a little more complex, but basically “for” is a loop inside javascript. This loop broken down is
    for //do loop in situation ( //bracket tells for loop to look inside here for the situation
    i=0; // i is a variable, and it equals 0
    i < ps.length; // if i is less than ps.length ( the value number for ps )
    *remember ps = parent.transform.scale.value; so it just add .length which calls for the number value*
    **in full its parent.transform.scale.value.length;**
    i++) // i++ means whatever i is, if before situation is still matching then add one to itself //bracket closes the for loop situation
    { //opens the for loop to allow you to apply something to every instance of the for loop
    *in the case above if the value was 50, it would do the for loop 50 times until it stops*
    s[i]=value[i]*100/ps[i]; //in this case it’s saying s[i] ^^ we saw i changes depending on the ‘ps.length’ and then calcutes it throughout
    s //outputs s
    so lets make an example for you:
    if the value of scale is 2
    s=[];
    ( loop broken down )
    s[0]=value[0]*100/ps[0];
    s[1]=value[1]*100/ps[1];
    s[2]=value[2]*100/ps[2];
    ( end loop )
    s
