Activity › Forums › Adobe After Effects › Expression bounce help
  • Expression bounce help
    Posted by Barry Evans on July 7, 2006 at 12:57 am
    I’m quite new to expressions and need a little help.
    I’m using the following to add a little bounce to an animation:
    t=time-key(2).time;
    if (t<0){
    value;
    }else{
    veloc = 18;
    amplitude = 60;
    decay = 6;
    y = amplitude*Math.cos(veloc*t)/Math.exp(decay*t);
    value+[0,0,y];
    Which starts the bounce on the second keyframe, does anyone know how i can modify it so the object bounces on every keyframe I add?
    Jack Hilkewich replied 20 years, 2 months ago 3 Members · 4 Replies
  • Dan Ebberts
    July 7, 2006 at 1:38 am
    Try this:
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n–;
    if (n == 0){
    value
    }else{
    t = time – key(n).time;
    veloc = 18;
    amplitude = 60;
    decay = 6;
    value+[0,0,y];
    Dan
  • Jack Hilkewich
    July 7, 2006 at 2:43 pm
    Plese forgive my intrusion but what attribute does one enter this into, position? I know very little about expressions but I try to use them when I can. I just can’t figure out where to put this.
  • Dan Ebberts
    July 7, 2006 at 3:03 pm
    Yes, this would be for position property of a 3D layer. The bounce will be in the z direction. If you wanted it to bounce a 2D layer in the y direction, you would just change this:
    value+[0,0,y];
    to thie:
    value+[0,y];
    Hope that helps.
    Dan
  • Jack Hilkewich
    July 7, 2006 at 3:22 pm
    Thanks a lot!
