Activity Forums Adobe After Effects expression advice
  • expression advice
    Posted by Guy on December 5, 2005 at 10:18 pm
    I have an expression to create a random wiggle on a 3D layer:
    seedRandom(13,true);
    wiggle(1,300)
    problem is, it is not smooth enough. I am using this layers postion to drive Particular’s emitter, and it creates “kinks” in the particles emitted.
    Changing the frequency (the #1 here) only slows the wiggle temporally.
    What I want are smoother, more gradual turns and curves.
    is there another line of code, or different expression that will give me wide, smooth curves?
    thanks!
    Ryan Hill replied 20 years, 8 months ago 3 Members · 3 Replies
  • Ryan Hill
    December 6, 2005 at 12:20 am
    I thought there was a parameter in wiggle that handles this, but I can’t remember it off the top of my head.
    In the meantime, you could apply the regular wiggle to a null and then average the current position of the null with the position it was in a few frames ago.
    That will make the turns a little smoother, though not really curved. It would turn a square corner into an octagon, for example. If you want something closer to a curve, average a greater number of samples, and it will increase the number of “sides” to each turn. Also, increasing the time span between samples will dull the corners more.
  • Mylenium
    December 6, 2005 at 9:01 am
    You can try to use the .smooth method. I can’t recall exactly, since I rarely use it, but should be something like that:
    my_wiggle=wiggle(1,30);
    my_smooth=my_wiggle.smooth(5,10);
    [my_smooth]
    Mylenium
    [Pour Myl
  • Ryan Hill
    January 1, 2006 at 9:36 pm
    When I try it that way, I get “function smooth is undefined.”
    But I got it to work by applying the wiggle to a slider control and then apply the smooth to another expression pick-whipped to that.
