Activity Forums Adobe After Effects expression
  • expression
    Posted by Chris Ruckert on September 17, 2008 at 3:52 am
    I often want to continue the exact rate of a parameter of a layer, indefinitely after the last keyframe, without having to actually make another keyframe and do the match.
    Is there an expression that will continue the motion after the keyframe at the speed/rate of the last keyframe.
    ohhh, this would be handy
    Darby Edelen replied 18 years ago 3 Members · 4 Replies
  • Darby Edelen
    September 17, 2008 at 4:33 am
    Okay, ready?…
    loopOut("continue");
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Chris Ruckert
    September 17, 2008 at 4:40 pm
    so simple. so handy. thx.
  • Glenn Stewart
    September 17, 2008 at 6:02 pm
    So I don’t need the “type =”?
    I love this expression, wish I had more opportunities to use it.
    Glennser
  • Darby Edelen
    September 17, 2008 at 7:18 pm
    [glenn stewart] “So I don’t need the “type =”?”
    No, that just creates a variable named ‘type’ that contains the string “continue” and then passes that variable into the function where it is stored in another variable.
    If you just type “continue” instead, you’re skipping the first variable assignment step.
    Darby Edelen
    NVIDIA
    Santa Clara, CA
