Activity › Forums › Adobe After Effects Expressions › Expression
Expression
Posted by Saso Goricar on February 26, 2020 at 7:57 pmHello,
I’ve created an animation of the stroke width from 0 to 10px with keyframes. Is there a way to create an expression, that I can change the width of the second keyframe with a controller?
Thanks, Saso
Saso Goricar replied 6 years, 6 months ago 3 Members · 6 Replies -
Marticus Kilverticus
February 28, 2020 at 3:19 pmSo long as youre only going between 2 keyframes, make a new slider somwhere with your width on it, then apply this to the strokes width:
width = (pickwhip to a new number slider);
linear(0,10,0,width)That just replaces 10 with your new sliders value.
Alex Printz
February 28, 2020 at 3:22 pmI’ve posted code below; just make sure your 2nd key’s value is different than the first key’s value (0px vs 10px).
linear(value, key(1).value, key(2).value, key(1).value, effect("Slider Value")(1))Alex Printz
Mograph Designer -
Saso Goricar
February 28, 2020 at 6:32 pmYes, you are both right, I used this linear expression
var y = comp("MOGRT").layer("MOGRT Controls").effect("Slider Control")("Slider")
linear(y,0,20,0,20);
I allowed max 20px of width.Thanks both for the idea for using this expression, I didn’t know that I could use it this way.
Saso Goricar
February 28, 2020 at 6:36 pmNo, It’s not working. The expression disable keyframes. I can control the width, but the width doesn’t animate from 0 to 20
Alex Printz
February 28, 2020 at 8:49 pmUse my expression above. The expression posted by the other user isn’t pulling anything from keyframes.
Alex Printz
Mograph Designer -
Saso Goricar
February 28, 2020 at 9:15 pmNow I got it, it works perfectly. Thanks for the help with my problem, it works. Thanks again.
