Activity › Forums › Avid Media Composer › Express Pro Dissolves not working – HELP
  • Express Pro Dissolves not working – HELP
    Posted by Steve Voyk on May 1, 2007 at 4:26 pm
    Avid Express Pro HD 5.5.3
    Hi guys,
    I’m editing PAL DV25 that has come in via P2 using the Media Tool.
    Footage looks fine, but as soon as I try and add a dissolve to the front or end of the clip, it plays fine, but if I render it, ONLY the dissolve part of the clip has the image scaled up by about 50%.. ie. I get a jump-cut with scaled up image at the transition point. As mentioned, it only happens after I hit render.
    Any ideas…. is it a bug of some kind?
    Regards,
    Steve
    Roger Bailey replied 18 years, 8 months ago 3 Members · 2 Replies
  • Grinner Hester
    May 1, 2007 at 4:57 pm
    first, try closing the bin your sequence is in and reopening it.
    then, try ditching your user settings and recreating them.
    I wish I could help you hone in on th cause of this. There are still just too many bugs to nail down.
  • Roger Bailey
    January 28, 2008 at 3:50 pm
    Hi, My friend has an Avid (version 4.1) and it has stopped making dissolves…I’m a FCP user but I thought someone might know if it’s a software of a hardware problem and if so which board it might be. Thanks, Roger
