Activity › Forums › Adobe After Effects Expressions › Expresion to change scale between two values….
  • Expresion to change scale between two values….
    Posted by Luis Garcia on October 20, 2015 at 9:37 am
    Hi! I need to get an expresion to do that in a layer the scale value (“x” value) changes in a ramdon mode between 11% and -11% (I would like to reverse the text…. I would need that the value will be or 11% or -11% and that it will change in a random mode….
    I have tried with a wiggle expression but I haven´t be able to do it… I get move the x value but I can´t get it into negative value, and therefore, it changes bit a bit.
    Someone could help me??
    Thanks in advance!!
    Luis Garcia replied 10 years, 11 months ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    October 20, 2015 at 6:53 pm
    I’d make a slider control set at 0 and add a wiggle expression to it. Then connect your scale property to the slider and set the scale to negative if the slider is <0 and positive if the slider is >=0.
  • Luis Garcia
    October 21, 2015 at 7:09 am
    Great!!!!! A lot of thanks!!! I can´t prove it now, but I will prove this afternoon and tell you if it works for me. I think that this will work sure… In any case, I will prove and tell you
    Thank you very, very, very much it helps me a lot!!!!
  • Luis Garcia
    October 22, 2015 at 8:45 am
    I have tried it and works perfectly!!
    A lot of thanks Kalle you are a great master!!!!!
    Thanks, thanks, thanks!
