Activity Forums Adobe After Effects expresion syntax error
  • expresion syntax error
    Posted by Benito Sanz on July 26, 2005 at 12:33 pm
    hi, i was doing a tutorial and i am using an expresio but af says there is a syntax erro, can anyone check if it is right, thank you.
    “this_comp. layer(this_layer, -1) . opacity. value_at_time ( time – .1)
    Benito Sanz replied 21 years, 2 months ago 2 Members · 2 Replies
  • Filip Vandueren
    July 26, 2005 at 1:23 pm
    It doesn’t give me an error in 6.5
    but try removing the spaces around the dots and see if that helps:
    this_comp.layer(this_layer, -1).opacity.value_at_time(time – .1);
  • Benito Sanz
    July 26, 2005 at 1:29 pm
    thanks filip it was the ” symbol in the end of the expresion.
