Activity Forums Apple Final Cut Pro Legacy Expoting Video Stills ?
  • Expoting Video Stills ?
    Posted by Anna Emdur on March 9, 2008 at 8:29 pm
    Hello,
    I am exporting video stills, the still are all in one sequence, the sequence settings are :720 x 480 lower even. I am exporting them into a self contained quicktime movie, i costume set the settings to match : 720 x 480, lower even.H.264
    The stills in the final movie have horizontal lines across them.
    These lines are not apparent before compressing.exporting.
    Can someone please guide me, what is the proper way to export stills without these lines. I would like to bring the stills int0 photoshop.
    THANKS!
    Anna Emdur replied 18 years, 6 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    March 9, 2008 at 9:10 pm
    Set your playhead on a frame you want to export as a still, then choose file/export/using QT conversion.. select still image from the pop up menu, and also select what format the still should be… i.e. PNG or Tiff etc.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Michael Gissing
    March 9, 2008 at 9:27 pm
    Use Jerry’s method and then in Photoshop you deinterlace.
  • Jerry Hofmann
    March 9, 2008 at 11:10 pm
    I normally don’t have to deinterlace… trick is to pick a still with little movement in the frame.
    Jerry
  • Anna Emdur
    March 10, 2008 at 5:11 am
    thank you all!
