Activity Forums Adobe After Effects Exports to After Effects
  • Exports to After Effects
    Posted by Paco Sweetman on November 30, 2006 at 12:51 pm
    I am cutting a film on HDV, I need to give an AE artist some footage to animate. What is the best workflow to go from FCP 5.0 to AE 6.5?
    Is targa sequence the best?
    It was shot on Sony Z1 1080i, 25 fps, PAL.
    thanks,
    Jon
    Wes Plate replied 19 years, 9 months ago 4 Members · 3 Replies
  • Nicholas Toth
    November 30, 2006 at 1:52 pm
    If you have the patience —
    Your AE guy will REALLY APPRECIATE THIS
    https://www.creative-workflow-hacks.com/2006/03/09/moving-between-final-cut-pro-and-after-effects-the-scripting-option/ (if you have intense cuts)
    An Animation codec or even a DV codec out of FCP via Compressor is the best way to go if you don’t want to do the above.
    I’d probably go native to what you shot in — DV — b/c you can’t make it any better.
    If you take the time to output with Compressor it looks a thousand times better than the stupid quicktime export.
  • Tony Kloiber
    November 30, 2006 at 2:36 pm
    Export the clip/clips buy creating a new sequence extend the in and outs (handles). Export using the same settings as the original media if you haven’t done any rendering on those clips FCP will just copy data from the original file and write it to a new file.
    TonyTony
  • Wes Plate
    December 1, 2006 at 9:12 pm
    A not-free, but FAST way to get an FCP sequence into AE (with each FCP clip as a separate AE layer) is Automatic Duck’s Pro Import AE.
    — Wes Plate
    Automatic Duck
