Activity Forums Apple Final Cut Pro Legacy Exports only Halfway!?!?!??!?!
  • Exports only Halfway!?!?!??!?!
    Posted by Acorn5 on August 23, 2005 at 11:00 am
    ARGH! i have no idea why my file exports only part-way everytime! i have tried exporting it many times, but the exported QT file ALWAYS stops at 8 min 16 sec…even though the file is supposed to be almost 10 min. The timeline looks ok…the files in the timeline look ok…everything seems to check out fine…
    Please please please help…
    Acorn5 replied 21 years ago 3 Members · 3 Replies
  • Tom Wolsky
    August 23, 2005 at 11:09 am
    Do you have an out point marked in the timeline?
  • Arnie Schlissel
    August 23, 2005 at 2:37 pm
    Here’s a rule of thumb: if the same bad thing always happens in the same place, then there’s a problem in that place.
    What’s going on at the 8:16 mark? Therein lies your problem.
    Arnie
    https://www.arniepix.com
  • Acorn5
    August 24, 2005 at 4:20 am
    Hmm…i do not have an in or out point…it’s just the timeline as it is…previously, with a different sequence preset, it exported the full file…but it was not in the resolution or frame ratio i wanted…after i changed it to NTSC and with resolution 640 x 480, it just kept stopping at the 8:16 mark…
    And the problem is, i don’t seem to see any problem at the 8:16 mark even though i keep scrubbing back and forth around that point…
