Activity Forums Adobe After Effects Exporting/Rendering at 16:10
  • Exporting/Rendering at 16:10
    Posted by Joshua Ralph on June 9, 2013 at 8:59 am
    Basically for a college project i created a spaceman animation, about 5 and a half minutes long. Since i love space art i used a large number of high quality backgrounds in my animation. Since my monitor is 1920×1200 all the backgrounds are the same resolution. I need a codec that will export my animation at 1920×1200 without sacrificing too much image quality. i cant go back and resize them as i simply dont have time. The codec must support this resolution. so far the only codec that seems to support it is AVI, the others just lock at 1920×1080. It also needs to compress, the 1000 mb/s data rate of my last attempt is a tad excessive 🙁
    I am currently on a windows but the video will be played back on both windows and mac only, its not going to DVD or on the web. i have both After Effects and Media Encoder.
    Ivan Myles replied 13 years, 3 months ago 3 Members · 2 Replies
  • John Cuevas
    June 9, 2013 at 4:49 pm
    Render out a master to AVI-Lossless master. Drag that into Media Encoder and now you can experiment a bit. I’d try creating a Quicktime then open up the “preset” side and select H.264 as your codec. I just tried a quick test and it’s working for me.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ivan Myles
    June 9, 2013 at 6:17 pm
    [Joshua Ralph] “I need a codec that will export my animation at 1920×1200 without sacrificing too much image quality.”
    Many codecs support non-standard resolutions. For the built-in Adobe (MainConcept) H.264 codec go to Basic Video Settings and first set the Level to 5.0 or 5.1; lower levels do not support 1200p. Then input the desired resolution.
    Note that these videos don’t always play well on Macs. The QuickTime H.264 codec is a better choice for cross-platform compatibility. Another alternative is to render an intermediate file and then transcode to MP4/H.264 using QuickTime Pro.
    [Joshua Ralph] “It also needs to compress, the 1000 mb/s data rate of my last attempt is a tad excessive :(“
    H.264 will probably be the best codec for your needs. The specific export settings will depend on your bitrate requirements. Max quality requires about 3 bpp; YouTube uses less than 0.1 bpp. That correlates to a range of about 5-158 mbps for a 1920×1200 video at 24fps. What is your desired average bitrate?
    A high bitrate VC-1/WMV video will produce slightly better quality than H.264, but I don’t know whether the wmv file will play on Macs. Use the free version of Microsoft Expression Encoder 4 if you would like to try VC-1.
