Activity Forums Apple Final Cut Pro Legacy exporting: XML Translation was aborted due to a critical error
  • exporting: XML Translation was aborted due to a critical error
    Posted by Peter Brelan on October 24, 2015 at 10:20 am
    I can’t export a XML to Davinci Resolve
    I get this message around 18% “XML Translation was aborted due to a critical error”
    If I unchecked “Save project last metadata” the export of the XML works, but if I need to keep metadata, how can I fix this problem???
    Thank you
    Pierre
    Peter Brelan replied 10 years, 10 months ago 1 Member · 2 Replies
  • Peter Brelan
    October 24, 2015 at 1:43 pm
    i’m think the problem comes from the multi clip editing, but even if I collapse the multi clip, I got the error. Do you know how to keep only the selected take in the multi clip?
  • Peter Brelan
    October 25, 2015 at 2:26 pm
    no finally, the problem doesn’t from the multiclip, I’m still looking for a solution
