Activity Forums DaVinci Resolve Exporting XML from FCPX but greyed out when trying to import into Resolve?
  • Exporting XML from FCPX but greyed out when trying to import into Resolve?
    Posted by Kaito Tanno on November 8, 2011 at 4:31 am
    Exporting XML to the desktop, trying to load into Resolve (Confirm / Timeline Man) but greyed out … help please ….
    Thanks Kai
    Kaito Tanno replied 14 years, 10 months ago 4 Members · 17 Replies
  • 17 Replies
  • Margus Voll
    November 8, 2011 at 6:36 am
    interesting. when i was testing similar thing all worked out nicely.
    can you give us more detailed description what and how you do it ?
    Margus
    https://iconstudios.eu
  • Kaito Tanno
    November 8, 2011 at 7:16 am
    I select the edit in FCPX’s project library and export via FILE / EXPORT XML
    I switch to Resolvego CONFIRM / TIMELINE MANAGEMENT / LOAD
    I see the file in the import box but it is Greyed out.
  • Ola Haldor voll
    November 8, 2011 at 8:57 am
    And you’re on Resolve 8.1?
  • Kaito Tanno
    November 8, 2011 at 9:22 am
    Apologies, yes Resolve 8.1 and FCPX 10.0.1
  • Christopher Tay
    November 8, 2011 at 10:04 am
    Did you check if your XML has the .xml extension ?
    -chrispy
  • Kaito Tanno
    November 8, 2011 at 10:39 am
    Hi Christopher ….. changed the file from .fcpxxml to .xml and now the file is no longer greyed out and I can select to import in DaVinci ….. however now I am getting “Invalid FCP XML FIle”.
    Perhaps small progress?
  • Margus Voll
    November 8, 2011 at 10:41 am
    have you done all updates to fcpx. seems like it is broken.
    Margus
  • Kaito Tanno
    November 8, 2011 at 11:08 am
    Yes both FCPX and Resolve are up to date
  • Ola Haldor voll
    November 8, 2011 at 11:17 am
    It should work with the .fcpxml extension.
    Try building a new sequence. Just put some random stuff in there and export a new FCPXML file.
    Even better – share the FCPXML with us to see if any of us can import it.
  • Kaito Tanno
    Do the original source files need to be moved? I surmise that Resolve should be able to link to the original source footage on my RAID through the XML file correct?
