Activity Forums Compression Techniques Exporting XDCAM HD from FCP through Compressor
  • Exporting XDCAM HD from FCP through Compressor
    Posted by Remington Swales on October 7, 2011 at 2:35 pm
    Hello all,
    I am working off an ’08 iMac 3.06 GHz Intel Core 2 Duo with 4 GB of RAM in FCP 7.0.3.
    I am editing and exporting a 30 minute show in XDCAM HD422 1080i60 (50 Mb/s).
    I’m exporting with XDCAM HD422 1080i60 (50 Mb/s) setting.
    Currently I am sending the show straight from FCP to Compressor adding the compression setting and submitting the export. It’s taking roughly 3 hours per show to export and Activity monitor is showing less than 50% of my processors are being used.
    I read other threads that recommended exporting a QT reference file from FCP and taking that into Compressor and using a virtual cluster. But a reference files take as long to export out of FCP as a self contained movie due to the Long GOP format of XDCAM (or so I read).
    I am just trying to speed up the exporting process as much as possible. So please help, I am open to any and all suggestions that will decrease my export time.
    SDP
    Remington Swales replied 14 years, 8 months ago 2 Members · 2 Replies
  • Brad Elliott
    October 13, 2011 at 8:01 pm
    I would not recommend exporting through Final Cut to Compressor via share. I have had more problems than not.
    In almost all instances the reference approach has given me the faster encode with the cluster approach.
    What are you converting the XDCam to in Compressor?
  • Remington Swales
    January 6, 2012 at 4:55 pm
    We are exporting it to XDCAM HD 1080i60.
