Activity Forums Apple Final Cut Pro Legacy Exporting XDCAM EX 1080p24 out of FCP to IDVD??
  • Exporting XDCAM EX 1080p24 out of FCP to IDVD??
    Posted by Tarik Sykes on June 10, 2010 at 6:25 am
    I made a reference file and put it in iDVD and it gets to the DVD BURN part and gives a “THere was a error during movie encoding” pop up! What do I do?
    Make Vids. 🙂 All Day and All Night
    Billet Video Studios(my production company)
    theWEBcentric (Freelance Video work)
    Sole Collector (SOLECOLLECTOR.COM)
    I love Nike Shoes
    Tarik Sykes replied 16 years, 3 months ago 2 Members · 2 Replies
  • Shane Ross
    June 10, 2010 at 7:23 am
    Don’t use iDVD. Use DVD Studio Pro. There’s an easy way to do this.
    #42 – Quick and dirty way to author a DVD
    Shane’s Stock Answer #42 – David Roth Weiss’ Secret Quick and Dirty Way to Author a DVD:
    The absolute simplest way to make a DVD using FCP and DVDSP is as follows:
    1. Export a QT movie, either a reference file or self contained using current settings.
    2. Open DVDSP, select the “graphical” tab and you will see two little monitors, one blue, one green.
    3. Select the left blue one and hit delete.
    4. Now, select the green one, right click on it amd select the top option “first play”.
    5. Now drag your QT from the broswer and drop it on top of the green monitor.
    6. Now, for a DVD from an HD source, look to the right side and select the “general tab” in the track editor, and see the Display Mode, and select “16:9 pan-scan.”
    7. Hit the little black and yellow burn icon at the top of the page and put a a DVD in when prompted. DVDSP will encode and burn your new DVD.
    THATS ALL!!!
    NOW…if you want a GOOD LOOKING DVD, instead of taking your REF movie into DVD SP, instead take it into Compressor and choose the BEST QUALITY ENCODE (2 pass VBR) that matches your show timing. Then take THAT result into DVD SP and follow the rest of the steps. Except you can choose “16:9 LETTERBOX” instead of PAN & SCAN if you want to see the entire image.
    Shane
  • Tarik Sykes
    June 10, 2010 at 8:18 am
    Thank you Mr. Ross! That was lots of help!
    I love Nike Shoes
