Activity Forums Apple Final Cut Pro Legacy Exporting with Transparent Background
  • Exporting with Transparent Background
    Posted by Colin Wiencek on June 17, 2008 at 1:59 am
    I need to export full quality lower third graphics for a client with a transparent background so that they can add it on top of their normal edits. I am wondering how I do this at full quality. I have tried the suggested animation compression with an alpha channel but a large amount of quality is lost in this method. Any suggestions?
    -Colin
    Chris Borjis replied 18 years, 3 months ago 5 Members · 5 Replies
  • Sean Oneil
    June 17, 2008 at 2:20 am
    [Colin Wiencek] “but a large amount of quality is lost in this metho”
    How did you form that conclusion? Animation at 100% quality is considered lossless.
    You can check out the Sheer video codec. I don’t remember if it can do alpha channels or not.
    Sean
  • Colin Wiencek
    June 17, 2008 at 2:23 am
    I came to that conclusion by looking at the source and the exported copy at full quality. The source was clearly better focused and more clear. I will try the Sheer codec and let you guys know.
    -Colin
  • Bret Williams
    June 17, 2008 at 2:27 am
    There should be no quality loss with the animation codec. Can you describe what you’re doing?
    If your client is using fcp, just create a project with lower 3rds only and email it. Your client would Copy and paste as needed.
  • Jeremy Garchow
    June 17, 2008 at 3:04 am
    [Colin Wiencek] “Any suggestions? “
    Yes. Where are you checking this quality? Quicktime? It sounds to me you are looking at a straight alpha channel which can look “distorted” until it’s composited correctly in a compositing program.
    Have you brought your exports back in to FCP or AE or Motion to check them?
    Jeremy
  • Chris Borjis
    June 17, 2008 at 4:43 am
    for this kind of thing I use a .psd with a single layer.
    drops right in and looks perfect without being a huge file size.
    and Jeremy is right, alpha’s can look ugly under certain conditions but should look perfect when played out.
