Activity Forums Apple Final Cut Pro Legacy Exporting with timecode burned in
  • Exporting with timecode burned in
    Posted by Kal Nyer on January 9, 2008 at 4:08 pm
    Hi all,
    I’m exporting low res quicktime files to be transcribed. Is it possible to burn in the original timecode so that the transcripts can reflect this?
    Jeremy Garchow replied 18 years, 8 months ago 4 Members · 6 Replies
  • Jeremy Garchow
    January 9, 2008 at 4:20 pm
    Yes. Get the Timecode Reader filter from your video effects folder. drag it to all of your clips, render and export.
  • John Pale
    January 9, 2008 at 4:42 pm
    If you are using Compressor 3 to make your Quicktimes, you can add the burned in timecode in the Filters pane.
    This is pretty cool, as you wont need to tie up FCP with rendering the burn in on a long program. Of course, Compressor will take a bit longer to make your Quicktime, but you can continue to use FCP.
  • Jeremy Garchow
    January 9, 2008 at 4:46 pm
    The only problem with compressor is that it will only do sequence tc and not clip tc (unless I am mistaken). For transcripts you need the clip tc.
    Jeremy
  • Walter Biscardi
    January 9, 2008 at 4:54 pm
    [John Pale] “If you are using Compressor 3 to make your Quicktimes, you can add the burned in timecode in the Filters pane.”
    This is exactly what we do with our transcriptions. We capture the clips into FCP, then quit out of FCP and bring the raw files directly into Compressor. Compressor reads the TC off the QT files so there’s no reason to get FCP involved once you’ve got the clips in. You can also set In / Out points in Compressor if you don’t need to transcribe an entire tape.
    Works much much faster than first rendering out the TC Window filter in FCP and then sending that into compressor.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Walter Biscardi
    January 9, 2008 at 4:55 pm
    [Jeremy Garchow] “The only problem with compressor is that it will only do sequence tc and not clip tc (unless I am mistaken). For transcripts you need the clip tc.”
    Compressor will do clip TC. You just bring the raw clips directly into Compressor. No need to use FCP at all.
    Read my Blog!
  • Jeremy Garchow
    January 9, 2008 at 5:03 pm
    Yes, thanks for pointing that out. It will do it clip by clip. I tend to lump one whole interview in a sequence and export as sending a couple hundred video clips to the transcriber can be daunting.
