Activity › Forums › Apple Final Cut Pro Legacy › exporting with mpegstreamclip
  • exporting with mpegstreamclip
    Posted by Grant Wilber on June 25, 2012 at 1:40 pm
    I was trying to export with mpeg streamclip. Made a non-self contained file out of fcp. Does anyone do this? If so what settings do you use? When I export from FCP at 1080 h.264 on ‘high’ my 3 minute movie comes out to about 128mbs. But on streamclip it comes out to 500mbs. How can I get this same small file size?
    Jerry Hofmann replied 14 years, 3 months ago 3 Members · 2 Replies
  • Rafael Amador
    June 25, 2012 at 1:58 pm
    Do you have the full FC sequence rendered?
    rafael
    http://www.nagavideo.com
  • Jerry Hofmann
    June 25, 2012 at 5:05 pm
    I don’t use MPEG Streamclip for much, but can you adjust the bit rate to match that of the setting in FCP’s export? If so, they’ll be the same size… But if it’s just low medium and high quality adjustments, the only way to make it smaller is to pick Medium or Low over high.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
