Activity Forums Apple Final Cut Pro Legacy Exporting with Compressor and Chapter Markers
  • Exporting with Compressor and Chapter Markers
    Posted by Phillip Gibb on June 20, 2005 at 12:39 pm
    I have always exported my projects as a Final Cut/QuickTime Movie. But after some sort of problem I have not been able to locate, I have to export using Compressor or I will get terrible interlacing over and section where there is quick movement.
    But I do not see an option to export with the Chapter Markers. Instead I have to export with Compressor and QT. Import both assets, add the QT asset to a track to get the markers, then delete the video and replace it with the Compressor compressed movie.
    I don’t really like using compressor because I have to wait 6 hours before simulating the DVD.
    Is there a was I can specify that the Chapter markers be including when using Compressor, or can I just export the markers to add later?
    Regards
    Phillip
    Jerry Hofmann replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 20, 2005 at 2:14 pm
    Export as before… i.e. use file/export/QuickTime… and include the chapter markers from a pop up menu in the dialog box you’ll see… then open Compressor and import that file… the chp. markers will be included.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
