Activity Forums Apple Final Cut Pro Legacy Exporting with 4 identical stereo audio channels
  • Exporting with 4 identical stereo audio channels
    Posted by Maria Maria on May 12, 2015 at 3:18 pm
    Hi everyone,
    I have been asked to export an edited video with four identical stereo channels.
    I’ll explain: in the timeline there are several tracks (voiceover, effects, music, etc.). They all need to be together in one single stereo channel, and I have to have this audio channel x 4. I don’t know if that was clear enough, but I’m hoping so.
    Any advice will be much appreciated.
    Nick Meyers replied 11 years, 4 months ago 3 Members · 4 Replies
  • Maria Maria
    May 12, 2015 at 5:16 pm
    One option I think would work, is to export all audio to one file, then import it back in the sequence, four times, in the four different tracks. Then set the sequence settings to 4 audio outputs (dual mono) and assign each track to each output… but I was hoping there would be a better, simpler option.
    Thanks again!
  • Shane Ross
    May 12, 2015 at 5:23 pm
    You cannot have one channel that’s stereo. It’s against the laws of nature. You can have a mono channel, or a STEREO LEFT channel, or a STEREO RIGHT channel. But not a single channel that’s stereo.
    So you can have 4 tracks, and export it as A1 Stereo Left, A2 Stereo Right, A3 Stereo Left, and A4 Stereo right.
    I have a tutorial that addresses this:
    https://library.creativecow.net/ross_shane/multi-audio/1
    Shane
    Little Frog Post
  • Maria Maria
    May 12, 2015 at 5:47 pm
    Thank you Shane, it’s always great to get a quick and professional answer in the CC forum. I realized you’re right… I had a chat with my colleagues and we’re gonna do it the way you suggest, because we think that’s actually the way the client was asking for.
    Thank you very much!
    Maria
  • Nick Meyers
    May 15, 2015 at 11:47 pm
    i think you should double check w the client.
    what you say they want doesn’t make sense to me:
    why have all the audio together in 2 identical steteo pairs?
    it’s more likely they want some difference between the two.
    one everything except VO & one VO
    OR
    one everything, the other everything except VO
    or some other combo
    nick
