Activity › Forums › Apple Final Cut Pro Legacy › Exporting Windows Media files – bit rate
  • Exporting Windows Media files – bit rate
    Posted by Miguelounge on July 24, 2006 at 4:39 pm
    Hello Guys,
    I’ve been trying to export a 1:00 minute FCP project into a Windows Media file. I have flip for Mac installed in my G5 so I can do 2 pass encoding. My problem is that even though I set the bit rate to 300 Kbps, the rendered file has a bit rate of over 800 Kbps. What can I do to get a final rendered file with a 300 Kbps bit rate?
    miguelounge
    Craig Seeman replied 20 years, 2 months ago 4 Members · 6 Replies
  • Craig Seeman
    July 24, 2006 at 4:58 pm
    You can’t use Quicktime Player to judge the bitrate of a WM file. If you use WMP9Mac it will show the peak rather than avg. bit rate. Best it check bitrate in WMP10 (XP) or ASFView (on Windows also).
    There’s a real need to check WM bit rate on the Mac.
  • David Roth weiss
    July 24, 2006 at 5:00 pm
    Call the support folks at the number on their website. Flip4MAC has very nice and attentive support personnel.
  • Miguelounge
    July 24, 2006 at 5:05 pm
    Hello Craig and thanks for your help,
    I’ve checked the bit rate in WMP10 (in windows XP) and still gives me a different bit rate than the one I had set. Please note that I’m working with constant bit rate
    miguelounge
  • Ed Dooley
    You could also see the total size of the file, and since you know the length
    of the video, do the math: total file size divided by seconds (60). A 300kbs
    data rate should give you something like 2.25MB for file size (add a little
    for overhead though). An 800kbs rate would give you a 6+MB file.
    Ed
  • Craig Seeman
    July 24, 2006 at 5:10 pm
    Go over to the Flip4Mac forum and post the issue.
    https://www.flip4mac.com/fusetalk/forum/
    They’ll respond and ask to see the file by email or FTP.
    There could be another issue lurking here. I usually find the bitrate within 5% of the target. If anything, it tends to be slightly under rather than over with CBR encodes.
  • Craig Seeman
    July 25, 2006 at 12:50 am
    The targeted bit rate was 396kbps and the actual bit rate showed as 406kbps in WMP10, ASFView and WMP9Mac. That’s very close to what it should be.
