Activity › Forums › Apple Final Cut Pro Legacy › Exporting Widescreen in FCP5
Posted by Sam Wheatley on November 15, 2007 at 10:19 pmHi
I
Sam Wheatley replied 18 years, 10 months ago 2 Members · 4 Replies -
Rafael Amador
November 16, 2007 at 3:22 amSam,
Normally QT display square pixels.
If you want QT display your movie Annamorphic, go to Properties (Comm-J)> Video Track> Visual Setting>
– Uncheck Preserve Aspect Ratio
– Set Scaled size: 1280×720> Intro.
No your image should look as you want.
rafael -
Sam Wheatley
November 16, 2007 at 9:29 amThanks for the reply.
I didn’t get around to doing that, I completed it last night. For some reason, it finally exported in widescreen, I didn’t make any changes to settings or the export ratio size and it just came out in widescreen. So I’m not sure what I did there.
I’ll have a look at the settings you suggested.
-Sam
Sam Wheatley
November 17, 2007 at 5:51 pmNo, the exact same way I was doing it, with Quicktime Conversion.
