Activity › Forums › Adobe After Effects › Exporting vs Render Que
Posted by Steve Montgomery on May 2, 2008 at 7:34 amWhich one should I use after I have finished my project. Are there reasons for using one over the other? Thank you
Kevin Camp replied 18 years, 4 months ago 3 Members · 2 Replies -
Itamar Kool
May 2, 2008 at 8:54 amUse the render que. Gives you much more choice to use the proper settings
Kool En De Anderen
MAC Pro 8 core/OS 10.4.11/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
http://www.koolendeanderen.nl -
Kevin Camp
May 2, 2008 at 2:06 pmalso, if you have cs3, multiple processors and have enabled the ‘render mulitple frames simultaneously’ option in the ae’s prefs, the render queue will take full advantage of those multiple processors, exporting doesn’t seem to….
but the main advantage is the added settings you have, and the ability to save the settings you use often. i’m pretty sure aharaon rabinowitz did an tutorial on rendering and the benefits of the render queue, and an overview of render settings and output module settings… click on his face on the ae forum page and search for ‘render’ or ‘render queue’.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
