Activity Forums Adobe Premiere Pro Exporting video with small file size best codec
  • Exporting video with small file size best codec
    Posted by Max Sidorov on October 10, 2008 at 7:43 am
    Im a super newb at this stuff and have tried to edumocate myself as much as possible and have tried exporting my video to a million combinations of the best codecs but the file size is super huge regardless.
    My video:
    50 minute quicktime video 640×480 thats 100 megs by itself.
    All i did in premiere pro 2.0 is add some titles (2) and some mp3 music at the beginning and end (does that affect file size?) thats it. When i export my video i get like 3 gigs minimum for decent video quality(wtf) when the original video thats 100 megs is great by itself. Somehow when i export it, it becomes super gigantic and becomes worse quality.. i dont get that. I want to save the original video quality (which is better in the original, than when i try to export unless the size is ginormous like 10 gis or more). I have tried h246, 263 and 261(crappy), avi, quicktime, and about a million combination with other codecs and file size is still huge. Is there any way i can stay under 500 megs (my original vid is only 100!!!!) and have the same quality vid and sound?
    Pls anyone if you know anything about exporting and codecs your help will be MUCH appreciated (i have been fiddling with codecs and different variation of exporting for about a week now, my cpu is poopy so i have to wait :(. Thank you in advance.
    Max
    Are Pi replied 10 years, 1 month ago 6 Members · 9 Replies
  • 9 Replies
  • Simon Bonner
    October 10, 2008 at 2:47 pm
    h.264 is the current codec of choice for high compression but decent quality. Install the newest quicktime to make use of it. But a 50min video is always going to be large. Your raw video is likely to be hugely compressed. All consumer cameras compress video heavily, or the amount of footage wouldn’t fit on the disc. This is why renders might not look so good: you’re compressing already compressed video, which is a recipe for poor quality.
    The titles shouldn’t increase file size so much. Your audio might be a problem though – if your video codec is compressed but your audio one isn’t, a very large proportion of the final file size could be down to the audio.
    Also, if you’re planning on uploading the video to youtube or some other website, you might consider outputting to 320×240 instead.
    Simon Bonner
    youtube.com/simonsaysFX
  • Max Sidorov
    October 10, 2008 at 6:58 pm
    Thanks for your quick response Simon!
    I will definitely fiddle around with audio compressors (can you suggest a good one?) and see if that gets the file size down. The video will be sold as part of a video course. Its 640×480 original and im going to stay with that, all i wanted was to keep the original quality. Anything else you may suggest? (like interlacing, audio settings etc.?)
    Thanks again,
    Max
  • Simon Bonner
    October 10, 2008 at 7:48 pm
    Hi Max,
    If you’re going to go h.264 (quicktime), it might be best to go with Apple AAC. Audio data rate 64 kbps, 16-bit, 44.1 khz mono should be fine for this form of delivery. I don’t know if you have this much control over your render from Premiere, so it might be worthwhile purchasing Quicktime pro, which is only about $15-20. Output using a lossless codec like QT animation or photo-jpeg and then compress in QT itself.
    You won’t want to interlace the videos if they’re for viewing on the web.
    If you’re selling the videos, you might want to consider opting for flv format as almost all computers have the flash player installed, but not every pc user will have Quicktime. Or you could just expressly state to your customers that they will need quicktime, and give them the link.
    Simon Bonner
  • Max Sidorov
    October 11, 2008 at 12:58 pm
    Simon you are my hero, i just fiddled with with it and found that it was the audio that took so much space (it was uncompressed before, now i used uLaw, i heard that one is good, any suggestions?). I exported my video and it was below 100 megs, perfect! Do you know what the option “Fields” does? It has “Lower fields firs” “Upper fields first” “No fields,” is that interlacing? I also left the checkbox “Optimize Stills” checked, hope that doesnt affect anything.
    You guys are a real blessing for us newbs!
    Thanks again Simon!
    Max
  • Simon Bonner
    October 11, 2008 at 10:54 pm
    Hi Max,
    I’m afraid I’m no expert when it comes to audio codecs. I’d suggest using your ear as a guide: if it sounds good on a range of playback devices and isn’t too large, then it’s ok.
    Upper vs. lower field first separation is indeed part of interlacing, though I’m also no great expert on this. I think I read somewhere that one is PAL and the other is NTSC, but don’t quote me on this. If you’re going progressive you shouldn’t need either.
    Simon Bonner
  • Francis Vila
    July 10, 2009 at 9:09 am
    Hi Simon,
    I have a 13 MB file in .wmv format and I tried to follow your advice by outputting in .mov with premiere. The movie is 10 mn long. I applied a chromakey filter in premiere, selected 22k compressed audio, mono, the output file size is 1 GB!!
    Windows Movie maker has an option that lets you adjust the final file size, in my case up from 7 MB. That really suits someone like me with no knowledge of video, but the list of effects in WMM is limited and doesn’t include chromakey.
    Is there any way that premiere or other software packages might be capable of outputting small movie files (I have a trial version of Premiere that expires this weekend) ? If WMM can do it, why can’t the others?
    My goal is to get a white background for a stamp-sized video to follow a screencam presentation. I am starting to think that, rather than try to edit the film using software, I might do better to film with a background as white as possible and make do with that…
    Any suggestions?
    Francis
  • Ishamel Moo
    June 3, 2013 at 1:48 pm
    im really struggling with exporting a video in adobe premier 5..its been 3months of trouble shooting,,im from the old premier times.im in africa (Pal)..i have tried a whole lot of the video codecs and i keep getting a monster file i cant carry it from the mac to any dvd,,i have raw footage well edited ,now making the video small as a quick time video is stressing me..its for my cousins wedding,,i need help please,,
  • Bill Dingli
    July 17, 2015 at 3:40 am
    I have surveyed many desperate posts about ADOBE PREMIERE and ENCODER producing unusable BLOATED FILE SIZE. It is now 17 Jul 2015 and I’m using the ADOBE CC suite all updated to 2015. Here are the facts. In all cases I matched source as best as I could using H264 codec and NO enhancements except one movie length reduction. All files were .MOV.
    (1) Orig movie 352×288 length 3m50 secs 65.5 megabytes cut to 352×288 length 1m 53secs –PremPro after import/export bloats it to 81.3 MB and Encoder “helps out” at 81.7MB.
    (2) After Effects generated movie (item A) 1920×1080 length 5m 6secs 8.35 GB (after saved to .MOV) which was imported to PremPro -no alterations of any kind with exactly matched sources and Prem Pro exported same resolution/length at 408.3MB as MP4 (using my MacBook Pro late 2011 with 16 GB ram standard video cards.)
    (3) Item A was loaded into You Tube at 1920×1080 and original 8.35GB and downloaded back. Clip converter downloaded a good quality 1920×1080 file with same attributes from You tube at 94.6 MB.and Savefrom.net downloaded it as a 1280×720 file at 78.2 MB.
    (4) Item A from Youtube at 94.6 MB was reloaded into PremPro and with no changes whatsoever was exported back to a .MP4 and bloated to 410.2 MB.
    TWO THINGS:
    1. Guys when you have your final movie, if the bloating is killing you, upload to Youtube (free) and download again using Clipconverter if you want 1920 resolution. Saveform.net does a good job but limited to 1280. I find the quality more than satisfactory (have a look at some of the latest 1920×1080 You Tube rock videos on a big screen) and you save the agony of searching for multiple methods to reduce a file in Premiere Pro.
    2. ADOBE WE HAVE A PROBLEM ! Firstly we urgently need test cases in your help manual that show how a movie from another source can be edited in PPro (assume same resolution and length) and for it to be exported without tear-jerking bloat. This detailed information would be very helpful.
    Secondly, if YOU TUBE can do such a great job in compression, maintain high quality and ask for no parameter setting from an inexperienced user, why can’t Adobe match You Tube and offer this alternative as an “Express Button” in Premiere Pro and Encoder ? When it comes to encoding quality for size, ADOBE, supposedly the professional tool, lags far behind YOU TUBE. Why should I have to go to YOU TUBE to compress my Adobe 50 minute movie to MP4 to fit onto a DVD ?
  • Are Pi
    August 22, 2016 at 11:03 am
    Alright so since you guys are giving a lot of value in this tread with a good few years of distance from eachother i thought id come by and drop my 2 cents here.
    Im using premiere CC and I noticed that the estimated vide file size what you see in the “make movie” window is really just an educated guess from premiers part regarding the size of the video. After tweaking the settings a tad bit I managed to get half the estimated size off of an actual render.
    So that being said my guess is that every or at least most settings count in the make movie window regarding the size and quality of the file. Also I believe that a Premiere Render Nirvana exists where you CAN get awesome quality and video file size but it never will be just so good as the youtube counterpart. Premiere must use a different rendering technology or rather YT uses a more advanced next gen render technology which completely blows by the competition (im just guessing).
    Also I think that youtube spent probably millions(if not tens of millions) of dollars on perfecting the encoding technology which Adobe could not afford to do when making the sofware thats why we get much better size/qualty ratios in YT.
