Activity › Forums › Apple Final Cut Pro Legacy › Exporting Video with Seperated Audio Tracks
Posted by Edmond Bina on November 24, 2008 at 8:33 pmI have a DVCPROHD video that has 6 audio tracks. 2 for Music, 2 for SFX and 2 for VO. I want to export out a DVCPROHD quicktime file without all of the tracks mixed into 2. This way the person I am giving it to can decide which tracks they want to use.
When I do a simple Export->Quicktime Movie it mixes all of the tracks into 2.
How can I get around that?
Chee Wee wee tan replied 17 years, 10 months ago 5 Members · 6 Replies -
Stace Carter
November 24, 2008 at 9:28 pmI know Quicktime will allow multiple audio tracks, however I’ve never had to use this feature.
In your export dialog, under “Setting” there’s a menu called “include”. Select Video Only and you’re golden, pretty basic.
You can then solo and export the audio tracks in other passes, or do it a little faster in STP.
Michael Gissing
November 24, 2008 at 11:05 pmYou can also export your audio as separate aif or wav files. Another option is to export your audio as an OMF. If you are handing over to a sound post facility, this is actually the best as they can have separate clips plus handles.
Exporting aif or wav will lock in your levels and provide no handles.
Rafael Amador
November 25, 2008 at 10:26 amI’ve never done that but I know that you can export from FC movies with 6 audio channels. This is mostly used for DVDs with surround audio or whatever.
Go to Users Preferences> Audio Output, and duplicate the “5.1 Monitoring” Preset. Open it to edit and check all the six channels as mono.
I guess than in your sequence setting should be Discreet Channels.
This together with a look to the FC manual may help you.
Cheers,
rafael -
Edmond Bina
November 26, 2008 at 1:02 amThanks,
What I did was go under Sequence->Settings->Audio Output, then selected 6 outputs, each dual mono.
Then I went to my audio tracks in each timeline and right clicked by A1, A2, etc and told each one which audio track to output to. That did the trick!
Now when I open it in quicktime or import it into an FCP timeline, I have all the tracks seperated so each one can be edited or removed individually.
Rafael Amador
November 26, 2008 at 1:28 amGood to know that it works and that easy.
This are the kind of things that you know are there but you only dig in when you really need it.
Cheers,
Rafael -
Chee Wee wee tan
November 27, 2008 at 4:32 am
