Activity Forums Apple Final Cut Pro Legacy Exporting Video for Youtube
  • Exporting Video for Youtube
    Posted by Emily Fine on February 6, 2008 at 9:02 pm
    Hi. I’m trying to export a 10 minute movie so that it is small enough to post on youtube (or split in 2 parts). But every time I’ve tried it’s either too large a file, horrible quality, or stutters. I don’t have the Final Cut manual with me. Can anyone recommend a format and compression that will work?
    Araw Deleon replied 16 years, 4 months ago 8 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    February 7, 2008 at 12:33 am
    [Emily Fine] “I don’t have the Final Cut manual with me.”
    Yes you do. It’s under the Help menu in Final Cut Pro.
    Use Compressor and limit the file size to 100MB. That’s about all you can do.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Zane Barker
    February 7, 2008 at 1:04 am
    If you have iMovie 08, then just export your video out of FCP using the current settings of the timeline, then pull that file into iMovie 08 and use the send to YouTube option.
    Don’t let technology get in the way of your creativity!
  • Eric June
    February 7, 2008 at 1:35 am
    If you export an FLV1 (Flash) format video, YouTube will accept your video without transcoding and causing the quality problems that you see. This article explains how you can “trick” YouTube into accepting a video that is longer than its length restrictions:
    https://forum.videohelp.com/topic336882.html
    If you have Adobe Flash CS3 Professional installed, you will have the option to export FLV via FCP –> QuickTime:
    https://livedocs.adobe.com/flash/9.0/flvencoder/wwhelp/wwhimpl/common/html/wwhelp.htm?context=LiveDocs_NoParts&file=FLV_03.html
    My ATV, Skiing and Hang Gliding videos: https://GrizzlyGuy.TV
  • Bill Kelly
    February 7, 2008 at 9:58 am
    You might want to check this out, then follow the post on the YouTube link. This dude got incredible quality by YouTube standards.
    https://www.lafcpug.org/phorum/read.php?1,198547,198547#msg-198547
  • Kristen Korns
    February 26, 2008 at 12:54 pm
    Hi there,
    I read this thread and am having a similar problem. I am overseas basically in the jungle and need to decrease the size of my video (800 MB) for uploading to youtube. I shot 16:9 and am having trouble keeping the format. I have never used compressor, so what settings and destination would I use, of course I would like the best quality possible. I am using FCP 6 but only have imovie HD, and need the final product to be less than 100 MB because the bandwidth is low.
  • Walter Biscardi
    February 26, 2008 at 1:50 pm
    [Kristen Korns] “I have never used compressor, so what settings and destination would I use, of course I would like the best quality possible.”
    Just set the file size to be a maximum 100MB like I suggested above. “High Qualty” and “YouTube” don’t go together. Even when you get your file under 100MB, YouTube will add another terrible layer of compression to your video turning it to mud. I have given up on trying to anything with quality on there.
    The videos that you see that ARE high quality, are those that YouTube has deals with to promote the show/movie/band/series, etc… They are allowed to post without that added layer of compression.
    Used to be if you kept your file under 100MB it would upload with no further compression. No more.
    Read my Blog!
  • John Elliott
    July 2, 2009 at 11:33 pm
    H.264
    FROM AFTER EFFECTS
    PAL WIDESCREEN SQUARE PIX 16:9
    25fps
    202.1mb
    Duration 00:01:56
    Really pleased with the results. It’s my best quality youtube upload so far!
  • Araw Deleon
    May 6, 2010 at 6:00 pm
    where is the setting to put a 100mb cap on the output?
