Activity › Forums › Compression Techniques › exporting video files
  • exporting video files
    Posted by James Laan on January 29, 2009 at 4:21 am
    i am trying to take clips from fcp6 and export them. then take the exported files and convert them into a viewable format. then burn the converted files on to a disc just as files to be viewed on a windows pc. my question would be, what is the best format to convert them to after i export them from final cut to maintain quality and to be viewed on a pc?
    James Laan replied 17 years, 8 months ago 2 Members · 6 Replies
  • Daniel Low
    January 29, 2009 at 7:39 am
    PCs and Macs aren’t that different, there are a bunch of different formats you could use. Is there something ‘special’ or lacking with the PC you are targeting?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • James Laan
    January 29, 2009 at 3:20 pm
    no nothing special. its for a friends pc and i dont know what format i should export in so he can view the files with no issues. but theres nothing wrong or special about his pc
  • Daniel Low
    January 29, 2009 at 4:38 pm
    If he has Quicktime installed (which he should if he cares at all about video) then use one of the Quicktime codecs like PhotoJPEG or H.264 or MPEG-4
    If you want full screen and high quality give give him MPEG-2.
    Otherwise you’ll be getting into the complicated world or Divx AVIs or WMVs
  • James Laan
    January 30, 2009 at 2:10 am
    can i export in mpeg-2 from fcp6?
  • Daniel Low
    January 30, 2009 at 7:52 am
    No, you’d use compressor.
  • James Laan
    January 31, 2009 at 12:21 am
    hey thanks alot. i really appreciate your help
    ill try that then respond back
    thanks again
