Activity › Forums › Apple Final Cut Pro Legacy › exporting via compressor vs. quicktime conversion for dvd out put
  • exporting via compressor vs. quicktime conversion for dvd out put
    Posted by Jared Kirshenbaum on September 13, 2006 at 3:09 am
    I was wondering and have read difference of opinions regarding exporting. If i export via quicktime conv for a 30-40 min or less video in h264 as a ref movie, can i then bring that ref movie into dvdsp4 and make a dvd? This way is would export quicker and be a lot smaller but still keep all the quality? Because I was told and read that you only make a self contained movie if you are giving it to someone else or you need to manipulate on another machine. Is that correct?
    Or should I export via sending it to compressor as an m2v, aiff and then make a dvd in dvdsp?
    Please someone shed some light, as i want the quickest export, not to tie up my fcp while it exports and still make a dvd that will play on a dvd player and not on my machine where ther ref file would be.
    Jared
    G4 Powerbook 1.67 1gb ddr
    Rafael Amador replied 20 years ago 5 Members · 8 Replies
  • 8 Replies
  • David Roth weiss
    September 13, 2006 at 4:24 am
    Jared,
    Make a QT reference movie from the timeline, that is very quick. Then, on the same machine, import that QT ref file into Compressor and make your mt2 video and ac3 audio files for making your DVD with dvdsp. You can go right back to editing in FCP while Compressor encodes. The only deal with a reference file is that it won’t work on another machine because it needs to reference the video files in your project, but any conversion or encode made using that reference file (as long as you do it on your machine) will be a standalone and complete file that will play on any machine.
    DRW
  • 13 Create COW Profile Image
    13
    September 13, 2006 at 6:13 am
    dont export H264 for a DVD export using the current settings of the project. even though H264 douse give good quality it is still compresed and sence DVD SP will have to compress it for DVD anyway you dont want your video to be compressed twice.
  • David Roth weiss
    September 13, 2006 at 9:14 am
    That’s right, no good reason to encode to h264 other than video for the web. Use Compressor to encode m2v video (typo in my last post) and ac3 audio files for making your DVD.
    DRW
  • Rafael Amador
    September 13, 2006 at 11:36 am
    I agreed jared,
    If you want the best of Compressor, give the best to Compressor. Although I work with an small DVCam, I output a 10bits Uncompress master-film, that keeps and shows all the god things that I (try) make to my footage amd all the richness of the graphics that I made in AE or so. Your DVDs will really apreciate it.
    salud,
    rafael
  • Joshua Booth
    September 13, 2006 at 1:50 pm
    Please elaborate more on your process for doing this. Thanks.
    -j
  • Rafael Amador
    September 14, 2006 at 4:05 am
    Hi Joshua,
    Are you asking for more information on how to do that?
    rafael
  • Joshua Booth
    September 14, 2006 at 5:49 pm
    yes. Thanks.
    -j
  • Rafael Amador
    September 18, 2006 at 2:22 am
    Joshua:
    What I do is basically edit in a DV time-line, and when you have everything ready to export, change the setting of the sequence to 8 or 10b Unc. Then you send from FC to Compressor directly, or export the movie first and then to Compressor. Try and tell me.
    Salud,
    rafael
