Activity Forums Adobe After Effects Exporting vector based image made in AE
  • Exporting vector based image made in AE
    Posted by Spencer Tycksen on July 18, 2012 at 7:06 pm
    is it possible to export a graphic that was created in after effects as a vector based image file that could be used in illustrator?
    Dan Fredley replied 14 years ago 2 Members · 1 Reply
  • Dan Fredley
    July 18, 2012 at 9:53 pm
    You might be able to do it through scripting, but it would take awhile to write something like that.
    The best I can think of is you can copy and paste your custom paths (either masks or shape layers) to Illustrator, but you’ll have to do it one layer at a time and then reapply fill, stroke and re-position them to other paths on other layers, etc.
    As far as I know you can’t copy built-in rectangle, ellipse or polystar paths from shape layers.
