Exporting uncompressed QT file
In the past, I’ve used Premiere Pro CS2 on a Windows machine, and when I wanted to save an uncompressed version of my project, I would simply go to file, export and create an AVI file. Very easy. I toss that file into my archive and I’m good to go.
My footage is SD, shot at 16:9 on a Canon XH-A1.
Now, I’m on the MAC side, and using CS4. I go to file, export, media:
Format: QuickTime
Preset: NTSC DV WidescreenI then export the file. When I play it back in QT, the file looks squeezed.
Through reading this form, and through experimentation, I’ve changed my preset to:
Format: Quicktime
Preset: (Custom)Under the video tab I change the width and height to 864 x 480.
I export using square pixels.
File plays back properly, but looks interlaced!
I’ve used the animation ‘compression’, none, and video. They all look interlaced. I’ve checked ‘deinterlace’ box in QT. Still looks the same.
I remember in CS2 that there was a box in the output dialog where I could check a ‘deinterlace’ option. I’m not finding that anymore.
Thanks in advance for any help.
Todd
Todd Feeback
http://www.toddfeeback.com
tfeeback@mac.com
