Activity › Forums › Apple Final Cut Pro Legacy › Exporting Uncompressed
  • Exporting Uncompressed
    Posted by Rocco Rocco on December 20, 2005 at 7:38 pm
    I have a workflow where I export via Quicktime Conversion from FCP5 at Uncompressed 8-bit (to import into After Effects).
    So, I place IN and OUT in the TL, select Export Using Quicktime Conversion. I then select Options, then Settings and chose Uncompressed 8-bit from the drop down box. Here’s the question:
    Why does it then say “Quality: Medium” in the little dilogue box there?
    This is confusing, as I require the highest settings…
    thanks for any input.
    Shane Ross replied 20 years, 9 months ago 2 Members · 3 Replies
  • Shane Ross
    December 20, 2005 at 8:37 pm
    Export at the native rate you are editing in…use Quicktime Movie, sequence settings, NOT quicktime Conversion. Even if you export uncompressed, you are compressing the footage. Only a QT Movie, self contained will add no further compression.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Rocco Rocco
    December 20, 2005 at 9:02 pm
    Thanks Shane. What if I select NONE as my “codec”? Is that an equivalent method (the large file size doesn’t matter to me as they are small clips)
  • Shane Ross
    December 20, 2005 at 9:45 pm
    No. NONE is a codec. Only exporting with as a QT movie with the sequence settings is a true lossless way of doing it.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
