Activity › Forums › Apple Final Cut Pro Legacy › Exporting uncollapsed Multiclip in FCP7
  • Exporting uncollapsed Multiclip in FCP7
    Posted by Michael Brown on April 4, 2016 at 3:26 pm
    Hi good People,
    What I mean is, is it possible to export the uncollapsed / unedited multiclip viewer window as a QT file in order to show someone all the angles at the same time (in motion picture of course, not as stills!)
    For the time being, I only see recording it off the screen as a possibility, but maybe there is a trick?
    Thanks for your support! best from the front 😉
    Michael Brown
    Michael Brown replied 10 years, 5 months ago 4 Members · 9 Replies
  • 9 Replies
  • Shane Ross
    April 4, 2016 at 5:11 pm
    Sorry, can’t. Only way to do that would be to layer the video and arrange the video manually.
    Shane
    Little Frog Post
  • Mark Suszko
    April 4, 2016 at 8:10 pm
    You cTrtainly could make the window larger, then screen record with Quicktime Pro, gets you essentially what you need.
    I suppose one could cheat and set up a split in FCP7 or Motion as well, then output that movie.
  • Michael Brown
    April 5, 2016 at 10:53 am
    Thanks Shane, I was afraid of that. Mark said I could screen record with QT Pro, but I don’t see a video source option in QT7 other than the facetime camera. Is there a short cut to select a window and screen record in QT Pro that I’m overseeing? or am I stuck with the option of videorecording the multiclip off the screen?
    Michael Brown
  • Michael Brown
    April 5, 2016 at 10:55 am
    Hi Mark, Shane claims it’s not possible, but I looked at my QT7 options and couldn’t locate a source video option other than the facetime camera (on Yosemite), because what you’re suggesting makes sense. Like a screen shot of a moving picture source, basically. What am I missing?
    Michael Brown
  • Nick Meyers
    April 5, 2016 at 11:17 am
    setting up a manual split screen is really not that difficult
    if it’s long, render overnight,
    export a reference movie and drop it into compressor to make your upload-able preview.
    nick
  • Michael Brown
    April 5, 2016 at 12:29 pm
    Thanks Nick, I’m aware of that, but I’m talking 20hrs + footage covered by 5 to 7 cams that I want to present (to a producer before editing). So it really IS a lot of work. It’s a pain as it is to create the dozens of MCs I need for editing, since I don’t have synced tc in my cameras, and I didn’t regenerate TCs (perhaps I should have, had I known) 😉
    Michael Brown
  • Nick Meyers
    April 5, 2016 at 1:03 pm
    ok, well buying a screen cap app is also not too hard!
    I’ve used iShowU in the past,
    Shane has recommendations, too, from memory
    i wonder how it’ll work when you’re trying to play back 5-7 streams of video
  • Mark Suszko
    April 5, 2016 at 4:41 pm
    Select “quicktime player”. Then “New Screen Recording”. When you activate it, you will be given the option of recording the entire screen or dragging to define a window.
  • Michael Brown
    April 5, 2016 at 6:09 pm
    Mark thanks. I was looking for that in QT Pro /, but you’re referring to QT 10, where I found it. Unfortunately no frame rate options and the likes. I found my share of happiness in iShowU where I have lots of options. Thanks mucho, guys!
    Michael Brown
