Activity Forums Apple Final Cut Pro Legacy Exporting two separated audio channels
  • Exporting two separated audio channels
    Posted by Sergio Deustua on November 17, 2006 at 6:10 pm
    Hello everybody.
    I need to export a clip from my FCP timeline. I need this new clip to contain the two audio channels mounted in the timeline and I need them separated, as in the timeline, not a stereo or mono mix but CH1 and CH2 whit independent information. Is there a way to do this?
    Thanks.
    Eric replied 19 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • David Roth weiss
    November 17, 2006 at 6:19 pm
    Sure. You simply need to disable the tracks you don’t want to hear and export the section you need using the tracks you do want to hear. So, right click on the track and you see the track enable/disable toggle. Does this make sense to you???
    DRW
  • Eric
    November 17, 2006 at 7:09 pm
    when you export “audio to aiff” you can choose grouped channels or stereo mix. choose “grouped channels” and you will have seperate files for each track.
  • Sergio Deustua
    November 20, 2006 at 9:56 am
    Thanks. That is a good step. But I need audio AND video in the clip. Is there a way to get the same resoult for audio (grouped channels) but with video included?.
    Thanks.
  • Eric
    November 20, 2006 at 1:54 pm
    under user prefs change your audio set-up to dual mono (not stereo).
    in your timeline settings set audio prefs to grouped. (make a new timeline not just change the setting)
    uncheck downmix in the audio mixer
    apply your clips
    export
    should do the trick
  • Sergio Deustua
    November 20, 2006 at 6:17 pm
    ok eric, that sounds good. will try out and let you know. thanks
  • Sergio Deustua
    November 22, 2006 at 5:06 pm
    thanks eric. it worked out!!
  • Eric
    November 28, 2006 at 2:41 pm
    great to hear that!
