Activity › Forums › Compression Techniques › Exporting TV ad
  • Exporting TV ad
    Posted by Dale Diasey on June 21, 2010 at 4:29 pm
    Im getting an advert ive done ready for broadcast in the UK. Theyve given me their preferred formats i.e:
    8 bit Uncompressed QuickTime
    625/50 Frames: 25 fps Frame size: 720 x 576 (16:9fha) Colour sampling: 4:2:2 (YUV) Field: Upper field first (odd) Audio: Integer (Little Endian) Sample rate: 48Khz Sample size: 16 bit Stereo
    Apple Pro Res (HQ)
    625/50 Frames: 25 fps Frame size 720 x 576 (16:9fha) Field: Upper field first Colour sampling: 4:2:2 Audio: Integer (Little Endian) Audio sample rate: 48Khz Sample size: 16 bit Stereo
    I was wondering which the best way of getting my advert to this format. I have it in after affects at the moment; would I render a lossless version from here and use another program to convert it or should i do it straight from AE. I have final cut and compressor if thats any use.
    Thanks in advance
    Dale Diasey replied 16 years, 3 months ago 2 Members · 2 Replies
  • Daniel Low
    June 21, 2010 at 8:36 pm
    FCP/compressor to Prores HQ
    Sent from my iPad Nano.
  • Dale Diasey
    June 22, 2010 at 8:10 am
    Thanks Daniel.
    Heard so many different things about this. A few people telling me to go straight from AE to the final output, which I wasnt sure was right, as I know AE wasnt designed for serious compression.
    I will follow your technique.
    thanks
