Activity › Forums › Avid Media Composer › Exporting troubles!
  • Jon Zanone
    December 19, 2005 at 1:00 pm
    Jason –
    Try being a little more specific. Are you using the same CPU, or are you transferring your export to another machine? What kind and version is your Avid software? What software are you using to encode, and what software are you using to author your DVD?
    Jon
  • Jason.w
    December 19, 2005 at 10:21 pm
    I’m using Avid Xpress Pro 5.0 and yes I’m using the same machine. I’m using Adobe Encore 1.5 for dvd authoring and encoding.
  • Jon Zanone
    December 20, 2005 at 12:43 pm
    When you start up Encore, do you bypass the screen where you select wether the project is PAL or NTSC? I seem to remember you can set up the program to automatically go into a new project without selecting your system. Try going into file>preferences and poke around there. Maybe your going straight into an NTSC project without knowing it….
    Jon
  • Jason.w
    December 20, 2005 at 4:42 pm
    I wish it was that easy. I’m quite sure I’m working in a PAL project.
