Activity › Forums › Apple Final Cut Pro Legacy › exporting to windows media file, FCP crashes
  • exporting to windows media file, FCP crashes
    Posted by Sherry Sakamoto on July 16, 2009 at 11:10 pm
    I’m trying to export a 4 second clip as a Windows media file using Quicktime conversion. It crashed. Discovered I had the freebie Flip4Mac so upgraded to Studio Pro version. Thought that would do the trick but when I try to export it, FCP still crashes. I am using OS 10.4.11, FCP 4.5, Quicktime 7.5 on a G5. Do I need Quicktime Pro? Thanks for any help.
    Sherry Sakamoto replied 17 years, 2 months ago 2 Members · 2 Replies
  • David Bogie
    July 17, 2009 at 3:43 pm
    [Sherry Sakamoto] “I’m trying to export a 4 second clip as a Windows media file using Quicktime conversion. It crashed. Discovered I had the freebie Flip4Mac so upgraded to Studio Pro version. “
    The freebie will export up to 30 seconds. “Crash” is impossible to understand from where I sit but it’s likely something wrong with your media, not the encoding process.
    [Sherry Sakamoto] “Thought that would do the trick but when I try to export it, FCP still crashes. I am using OS 10.4.11, FCP 4.5, Quicktime 7.5 on a G5. Do I need Quicktime Pro? Thanks for any help. “
    You already have QT Pro. The Final Cut Studio is based on QTPro.
    You have not said what the original file is or what your sequence settings are. Those may not make any difference but it’s helpful to know in debugging a failed export.
    bogiesan
  • Sherry Sakamoto
    July 17, 2009 at 5:19 pm
    I don’t have FC Studio so don’t have QT Pro. I had FCP 4.5 before the package was created and don’t need Motion, etc so have never bother to buy it. That’s why I was wondering if QT Pro would make any difference to solving my problem. My original file is NTSC 4:3 standard def.
