Activity Forums Adobe After Effects exporting to .swf
  • exporting to .swf
    Posted by Big Beres on July 29, 2007 at 4:43 am
    I can not seem to get a .swf file to play (it was made with AE CS3), (playing in dreamweaver CS3 and flash)
    It has a text layer and a fractal Noise layer.
    I tried making the .swf file with a text layer only and it worked fine, so then I tried making the .swf file with only the fractal noise layer and it didn’t work.
    Is there something I must do to the fractal noise layet before I export to .swf
    Kevin Camp replied 19 years, 1 month ago 2 Members · 1 Reply
  • Kevin Camp
    July 30, 2007 at 7:40 pm
    there has been mention of .swf export problems (i’m not sure of the specifics). but i think you could pre-comp the fractal noise layer, then pre-render that. go back to your main comp and the fractal noise layer should now be rendered footage. try exporting that comp.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
