Activity Forums Apple Final Cut Pro Legacy Exporting to Soundtrack
  • Exporting to Soundtrack
    Posted by Glenn Woiler on January 4, 2006 at 5:11 pm
    I am trying to export a sequence to Soundtrack. I only have audio tracks. I am editing 40
    videos for radio and only have the soundtracks on the timeline. When I go to export to
    soundtrack, (I need to make MP3’s) the “Audio” only option is grayed out. I can only export
    as Video and Audio together or just video. Is this a bug… or what am I missing? I have tried
    toggling various settings on the video track with no change. Thanks in advance for your
    help.
    Glennn
    Gary Hughes replied 20 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Bouncing Account needs new email address
    January 4, 2006 at 5:33 pm
    Use this:
    File > Export > Audio to AIFF(s)
    You can also use iTunes to make very good quality mp3s from AIFF(s).
  • Glenn Woiler
    January 4, 2006 at 6:21 pm
    Well… I could, but that is an extra step. This SHOULD work, but it doesn’t. With 40 half hour programs, I just want to send to Soundtrack and crunch a MP3.
  • Frank Nolan
    January 4, 2006 at 8:51 pm
    This DOES work if you ask it nicely or at least tell it the right command. Instead of going File>export for soundtrack. Go File>SEND TO>Soundtrack Pro multi project. Then when the next window pops up to name the project, UNCHECK the box that says include background video.
  • Glenn Woiler
    January 4, 2006 at 9:39 pm
    I tried. In the Send To box everything is grayed out except the Soundtrack Pro Script. I even started Soundtrack but no-go. I wonder if the update will fix this? My boss told me there is one available for FCP so I will get it tonight. Any other ideas?
    glenn
  • Frank Nolan
    January 4, 2006 at 9:44 pm
    Did you have the sequence selected in the browser when you tried this?
  • Glenn Woiler
    January 4, 2006 at 10:10 pm
    I’m still new to FCP even though I have used it just for DVD preparation and DVDStudio Pro for 2 years. I just never edited that much. But we just moved the Stratosphere out and now here we are. I always had the sequence active by clicking in it… but that was not enough. thanks again.
    Glenn
  • Gary Hughes
    January 5, 2006 at 8:47 am
    You might want to check out SoundConverter. https://www.dekorte.com/projects/shareware/SoundConverter/ It’s a cool little $10 app that batch converts. You could actually batch export via compressor to aiff, then use this app to batch convert to mp3. You just drag a file or group of files and drop them on the open app and it converts them to the settings that you previously set up and saves them in their original folder. I use it all the time to convert 44.1 stereo mp3’s to 48k mono aiff’s, as well as my producer sends me scratch VO tracks from his ibook in m4a files. Again, stereo 44.1 to mono 48k aiff to use in fcp. I never convert audio in iTunes anymore.
    Have fun.
    Gary
