Activity › Forums › Apple Final Cut Pro Legacy › Exporting to FLV file
Posted by Lukenator on December 15, 2005 at 12:05 pmHow do I export a 720 x 480 movie to Flash (.flv) and avoid seeing the black edge (usually outside the safety area and not visible on video monitors)?
Thanks.
Lukenator replied 20 years, 9 months ago 2 Members · 4 Replies -
Enzo Tedeschi
December 15, 2005 at 9:19 pmHad this issue recently with videos for a Flash CD-ROM.
My solution was to nest the sequence, and scale it up (only by about 4%, that’s usually enough in PAL) to get rid of the black, and then export the movie. Because the FLV format is going to compress the heck out of it anyway, you won’t notice the slight softness introduced by the scaling.
Enzo Tedeschi
____________________________
Editor
Sydney, Australia -
Lukenator
December 15, 2005 at 10:54 pmthanks for your reply. I understand that I will need to scale it up. What does it mean to “nest the sequence?” I have many many sequences to scale up.
thanks
Enzo Tedeschi
December 16, 2005 at 8:52 pmYou’re welcome.
Nesting is like creating one big clip from all your clips. If you select all the video clips in one sequence, and then go Modify > Nest Items (or somewhere around there in the menus), all your clips on the timeline will be submastered into what appears to be one big clip. Don’t worry, you can still access the individual clips by double-clicking the nested clip.
What this does is it enables you to apply filters or scaling etc to ALL the clips at once, rather than having to scale up every cut in the sequence. To do this, click on the nested clip in the timeline, and hit Enter. This will load it into the viewer where uyou can scale and keyframe like you would any other clip.
Enzo Tedeschi
Editor
Sydney, Australia
