Activity Forums Apple Final Cut Pro Legacy exporting to .flv
  • exporting to .flv
    Posted by Matt Shires on June 24, 2009 at 7:51 pm
    wondering if anyone can help
    2 questions really as I only got adobe the other week.
    1. How come when I go to export a FLV file from FCP or compressor I’m not given the option in the settings even though I’ve installed Production Premium on my mac? Is it a case of having to mess around with preferences or am i missing something?
    2. what’s the dif between .flv and f4v?
    Many thanks for any suggestions or advice.
    Cheers, Matt
    John Fishback replied 17 years, 2 months ago 4 Members · 4 Replies
  • Steve Eisen
    June 24, 2009 at 8:49 pm
    https://www.video-to-flash.com/f4v-h264-flv/
    You could have done the search yourself.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Matt Shires
    June 25, 2009 at 11:12 am
    Thanks Steve, appreciate the link,
    however doesn’t answer why I can’t export .flv files from FCP. When I go to export either by quicktime, compressor or quicktime conversions I’m not give the option. I have Adobe production premium installed on the machine so thought I’d be able to, perhaps misguided?
  • Rafael Amador
    June 25, 2009 at 12:08 pm
    Hi Matt,
    Go to your Main> Library> QuickTime and make sure that you have the “FLV.component”.
    [matt shires] “2. what’s the dif between .flv and f4v? “
    I think that is an Flash H264. I think that is you change the extension of a QT h264 to .f4v, Flash player will read it.
    .m4v is one of the possible QT MP4 extensions.
    Rafael
    http://www.nagavideo.com
  • John Fishback
    June 25, 2009 at 9:15 pm
    Have you installed Flash Encoder? You need that for QT or FCP to export flv. When you Export from QT you choose Movie to Flash Video (flv). When you click Options you can adjust various settings. In FCP, Export Using QT Conversion. In Format choose Flash Video (flv). Options works as mentioned above. I’ve never used Compressor to make flvs (I use Sorenson Squeeze). I’m not sure you can make flvs with Compressor, but you can make an H.264 and change the extension from .mov to .flv and it will work. The latest Flash Player will work with H.264 files with the extension changed to .flv.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
