Activity Forums Adobe After Effects Exporting to Flash in AE CS5
  • Exporting to Flash in AE CS5
    Posted by Scott Muff on September 14, 2010 at 7:24 pm
    Hi All,
    I have created a composition in AE CS5 that is 42 seconds long. I would like to export to SWF for playback on a website but I am running into a problem somewhere.
    When I export (File/Export/AdobeFlashPlayer(SWF) I seems to export the animation. I runs through the process showing all of the frams being rendered.
    When I drop it into an HTML page or view it in a Flash Viewer I only see 32 seconds of the animaiton. I did this with a shorter animation yesterday with no problems. My assumtion is that I am missing something somewhere.
    Any help would be greatly appreciated.
    Scott
    Michael Sisko replied 15 years, 11 months ago 2 Members · 1 Reply
  • Michael Sisko
    September 16, 2010 at 8:24 pm
    I have run into the same issues, check your render settings on the 42 sec comp to make sure you are rendering the full comp. if you have Adobe Flash you can also use that to take a .mov or mpeg and that will give you your swf. Hope that helps. Let me Know
    Michael
