Activity Forums Avid Media Composer Exporting To File On AVID MC5
  • Exporting To File On AVID MC5
    Posted by Eddie Gonzalez on June 20, 2011 at 6:15 pm
    Two specific questions (see bottom for more info).
    Question 1) When I export to a file, which of the following options do you recommend that I select from the pull down menu in Avid MC5 ?
    * Fast-Export Quick Time NTSC
    * Make New – Quick Time Reference
    * Quick Time Reference
    * Quick Time Reference DV Codec
    * Send To QT Movie
    * Sorenson Squeeze
    * Untitled
    * Windows Image NTSC
    Question 2)
    After I make the above selection, I then click on Options which opens another window with more options, so then which of these options should I select from the following pull down menu?
    >> “Export As”
    * HDV
    * DV Stream
    * Quick Time Movie
    * AVI
    * Windows Media
    ________________
    As a newbie I have myriad questions, but for now I only need help with the above two questions. The resulting file will be 720P 59.94fps and of High Def broadcast quality so that I can send it to any media buyer that will then put it on HDCAM-SR or D5 for sending tapes (or the file) to various HD networks for airing.
    Jeff Greenberg replied 15 years, 2 months ago 3 Members · 3 Replies
  • Brendan Maghran
    June 20, 2011 at 7:59 pm
    What is your editing codec? What is the final codec/file format you’re going for?
    If you’re just exporting for DNxHD…
    1. Send to QT movie
    2. Export as Quicktime movie or same as source (if you cut DNx)
  • Eddie Gonzalez
    June 20, 2011 at 8:40 pm
    Brendan, thank you. I didn’t know whether or not i’d get a response to my questions so I called up a media buyer and they answered my questions on the phone. You’re correct Brendan. He said exactly the answer you gave me.
    Send to QT Movie
    & then
    Quick Time Movie
    They’re even more flexible than that too because they will convert the file to whatever the networks need. But my thought was to send them a file that they don’t need to convert. I wanted them to have to do as little manipulating as possible.
  • Jeff Greenberg
    June 27, 2011 at 1:42 pm
    Call then back and ask them what would be most helpful.
    Export to Squeeze (which is a QuickTime ref file) and then compress it into exactly what they need.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
