Activity › Forums › Apple Final Cut Pro Legacy › Exporting to Compressor
  • Exporting to Compressor
    Posted by Bob Anderson on November 4, 2010 at 8:14 pm
    I’m using Compressor for the first time since I upgraded my FCS which I assume upgraded Compressor to 3.5. I’m converting my FCP project to make DVDs. When I submit my project, it simply says “waiting,” and does nothing. Is there a setting I’m missing or what’s going on?
    Robert Anderson replied 15 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    November 5, 2010 at 1:27 pm
    Are you just using file/send to/compressor? Wonder if trashing your plist for compressor might fix this and/or trashing prefs for FCP… It’s not a bug nor is it a bad setting you could change don’t think.
    If you export a self contained movie and open that in Compressor instead, then I’ll wager it will work OK, and still allow you to work in FCP during the compression… If you export a non self contained file, it should work OK too and be pretty fast if all of the renders are complete in your source sequence.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Robert Anderson
    November 5, 2010 at 2:41 pm
    I exported a self contained movie and tried that with the same results. I’ll try trashing the plist for compressor. Thanks.
  • Jerry Hofmann
    November 5, 2010 at 3:14 pm
    Yeah, do that, and it’s good news actually that the self contained file exported OK. This does point right at something gone wonky in Compressor.
    Troubleshooting is always a matter of ruling out the possibilities one at a time.
    Jerry
  • Robert Anderson
    November 5, 2010 at 4:16 pm
    Actually, not sure how to trash the plist in Compressor.
  • Jerry Hofmann
    November 5, 2010 at 6:04 pm
    It’s the file located at Mac HD/Library/preferences folder/ you’ll find it there. just drag it to the trash, and restart your apps! It get’s rebuilt to factory settings upon relaunch. Don’t empty the trash until you’ve found success so you could put it back if need be. Maybe put it on the desktop first? I’ve never seen a problem doing this however.
    Jerry
  • Robert Anderson
    November 5, 2010 at 6:14 pm
    Thanks. I’ll try that.
  • Robert Anderson
    November 5, 2010 at 6:21 pm
    I don’t see a compressor plist. is it called something else?
