Activity Forums Adobe Premiere Pro Exporting to Betacam SP
  • Exporting to Betacam SP
    Posted by Clyde Villegas on November 14, 2008 at 2:31 am
    I export to miniDV using the export command. I use a small camcorder as a recorder. How do you export to Betacam SP? I haven’t used a betacam deck. Do they have firewire inputs so Premiere can detect it? Or should I export through my breakout box’s component output? What is the industry’s practice (or at least a practical solution) in exporting to Betacam SP?
    ut in omnibus glorificetur Deus
    Clyde Villegas replied 17 years, 10 months ago 5 Members · 9 Replies
  • 9 Replies
  • Jon Barrie
    November 14, 2008 at 2:45 am
    Betacam is a Professional Broadcast Quality Format. It uses a Serial connection and not FW. It has component output/input via SDI so I think you’re outta luck with your software based system. Betacam decks are extremely expensive and most prod co’s don’t own one. Hiring is expensive too, then you need the Hardware to talk to it (AJA, Black Magic, Matrox AXIO to name a few).
    If I need to do that I go to a Big Post House that charges to put a Video file from a HDD out to the Betacam maching. It’s not cheap so be aware it will cost you $$$ no matter how you transfer.
    I usually export my video to Uncompressed AVI or QT Animation codec. These two digital formats are lossless. QT Animation can be smaller in data size than Uncmopressed AVI. Ask the Post House what they prefer. There systems will be setup for RT playback and optimized for certain file codecs.
    Hope that helps.
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Clyde Villegas
    November 14, 2008 at 6:32 am
    [Jon Barrie] “Betacam is a Professional Broadcast Quality Format. It uses a Serial connection and not FW. It has component output/input via SDI so I think you’re outta luck with your software based system.”
    Thanks Jon! But do you mean big post production houses don’t use Premiere Pro and other software based systems? What do they use?
  • Jon Barrie
    November 14, 2008 at 10:27 am
    I’m not saying that they don’t use the same software. Matrox AXIO is only for Premiere Pro. AJA is for Premiere Pro and Final Cut Pro. Then there are Avid (which has it’s own hardware solutions) and is the most popular system in Big Prod Houses. A video file is a video file. Hardware is available for many softwares.
    At the end of the day you need to put your video onto Betacam. Nobody knows what you cut it on or even care. If you had the right hardware you can use Premiere to go to Betacam. Black Magic and Matrox AXIO are the two most popular Full HD Hardware for Premiere Pro.
    Jon Barrie
    aJBprods
  • Jeff Brown
    November 14, 2008 at 3:28 pm
    BetaCam comes in 2 variations: BetaCamSP, and BetaCam Digital (commonly called DigiBeta). DigiBeta has SDI in/out. BOTH have component in/out, which will produce a perfectly fine recording.
    Neither have Firewire connections. BetaSP also has 3 variants: the BVW series, the PVW series, and the UVW series. The recording specs for the BVW and PVW are a little bit better than the UVW series.
    Important note: DigiBeta will play BetaSP (analog) tapes, but the analog decks will not play DigiBeta tapes.
    For deck control, you would need an RS-422 connection to your system. You can just “crash record” without the RS-422: hit record on the deck, wait about 10 seconds, then hit “play” in Premiere. This does not give you a professional leader, though (color bars, tone, etc., at exact timecode points).
    Both analog and digital Beta decks want house sync, but you can probably provide this by sending composite out from your system to the Reference In of the deck.
    You should be able to rent a Beta deck for about $250 – $450 a day, depending on the deck & your market.
    I have had a PVW deck for almost 15 years now; though anymore I use it about once every 6 months.
    -jeff
  • David Erwin
    November 14, 2008 at 4:27 pm
    I have a black magic card on order so I can import the company’s legacy footage off of betacam and other formats.
    If I decided to export back to tape (out of a 1080i project) would Premiere automatically do a down convert or will that be dependent on the capabilities of the black magic card
    thanks
    de
  • Dave Friend
    November 14, 2008 at 8:29 pm
    It will depend on the BMD card.
  • Clyde Villegas
    November 15, 2008 at 2:40 am
    [Jeff Brown] “For deck control, you would need an RS-422 connection to your system. You can just “crash record” without the RS-422: hit record on the deck, wait about 10 seconds, then hit “play” in Premiere.”
    What is RS422? Is it an interface card? If I install it, will Premiere talk to the deck like it talks to my miniDV recorder?
    [Jeff Brown] “I have had a PVW deck for almost 15 years now; though anymore I use it about once every 6 months.”
    Since you use it every 6 months, then most of your clients must be requiring some formats other than Betacam. What do most of them require? Here in the Philippines, whenever I talk to some friends and acquaintances in ad agencies and television networks, they tell me they almost always require Betacam. Is this also true for the U.S.?
  • Jeff Brown
    November 16, 2008 at 5:07 pm
    RS-422 is a type of serial connection. Typically, a video I/O card (like AJA or BlackMagic) will have this connection for deck control.
    Most of my work is short-form animation and visual effects; I’ve been able to demonstrate to my clients that importing a digital file to their systems provides the highest quality. But– they are the ones doing the final edit.
    So, I don’t have to do much in the way of broadcast deliverables, but for SD work here in the states, Digital BetaCam would probably be the most common deliverable.
    The important thing is: if your client wants BetaCam, give them BetaCam!
    -jeff
  • Clyde Villegas
    November 17, 2008 at 10:48 pm
    [Jeff Brown] “but for SD work here in the states, Digital BetaCam would probably be the most common deliverable.”
    How about HD, what is the most common delivery format? Thanks Jeff.
