Activity Forums Apple Final Cut Pro Legacy Exporting to Avid Uncompressed Codec
  • Exporting to Avid Uncompressed Codec
    Posted by Matt Hargrave on July 18, 2011 at 8:25 am
    Hi everyone, I’m trying to export some files to a client who is asking for “QT files to use Avid Uncompressed codec, RGB, 1920 x 1080 progressive” and I am using FCP. I downloaded the Avid codecs from their website but get an error message whenever I try to use them in both FCP and Compressor. I’ve tried mixing and matching lots of different options but I get an error immediately every time I try to export/compress. Here are my settings when using Compressor with the Avid codec:
    Name: Avid Meridien Uncompressed
    Description: No description
    File Extension: mov
    Estimated size: unknown
    Video Encoder
    Format: QT
    Width: 1920
    Height: 1080
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls: Automatically selected: Off
    Codec Type: Avid Meridien Uncompressed
    Multi-pass: Off, frame reorder: Off
    Pixel depth: 32
    Spatial quality: 100
    Min. Spatial quality: 0
    Temporal quality: 0
    Min. temporal quality: 0
    Any help or insight would be greatly appreciated.
    Cheers,
    Matt
    Matt Hargrave replied 15 years, 2 months ago 2 Members · 2 Replies
  • John Pale
    July 19, 2011 at 4:11 am
    don’t use Meridien for HD.
    Use Avid 1:1x if you want uncompressed.
  • Matt Hargrave
    July 19, 2011 at 5:49 am
    Great! Thanks John, that works perfectly.
