Activity › Forums › Apple Final Cut Pro › Exporting to After Effects (round tripping) — 5 second clip!
Posted by Richard Herd on February 27, 2012 at 10:17 pmI can’t figure out how to do this.
I use the Range Selector but it keeps exporting the whole project file, not just the little bit I selected.
I’ve been reading the manual but it doesn’t seem to help either.
Thomas Szabo replied 14 years, 3 months ago 6 Members · 5 Replies -
Erik Lindahl
February 27, 2012 at 10:39 pmI don’t think FCPX supports ranged based exports in its current state.
Michael Hadley
February 27, 2012 at 11:05 pmThis may be just the tool you need (but looks like it only works with FCPX 10.0.2, not .03). It’s pretty cool.
https://fcp.co/final-cut-pro/news/550-foolcu-the-fcpx-to-after-effects-apple-script-in-action
Good luck.
Noah Kadner
February 28, 2012 at 2:00 amThe simplest method to export a short range from a project is to select everything, make it into a Compound clip and then trim that clip. Then re-expand. Or send via Compressor which allows you to set shorter pieces…
Noah
Call Box Training.
Featuring the Panasonic GH2 and Panasonic AC160/130. -
Jamal Watts
February 28, 2012 at 2:52 amYou can try it/do it like this too. https://www.youtube.com/watch?v=XzCCfkQKBwE
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Thomas Szabo
May 29, 2012 at 3:54 pmClipExporter exports FCP X clips as Quicktime reference movies. It also translates your entire timelines to After Effects which is a lot faster than the workflow suggested by Jamal Watts. Maybe this helps. See the ClipExporter website.
Thomas
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
