Activity › Forums › Apple Final Cut Pro Legacy › exporting to a small QT file
Posted by Dennis Allen on January 24, 2009 at 8:41 pmI am using FCP 5.1 and would like to export a four minute movie so I can email it. Help.
Steve Eisen replied 17 years, 8 months ago 3 Members · 3 Replies -
Steve Eisen
January 24, 2009 at 9:50 pmuse compressor
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Glenn Fisher
January 25, 2009 at 12:19 amSteve is right.
From Final Cut Pro, choose File -> Export -> Export to Compressor. That will automatically launch the Compressor application. In the “Settings” window, choose Apple -> Formats -> Quicktime -> H.264. Highlight that preset and then drag it up to where it says “Drag Settings and Destinations Here.” After that, you can right click (ctrl-click) where it says “Source” and choose your own destination from the contextual menu. Click submit, and compressor will begin cranking away at the file. To check the status of the compression, you’ll want to open up the Batch Monitor.
I hope that helps. Best of luck!
– Glenn Fisher
Steve Eisen
January 25, 2009 at 12:55 amGlenn you gave Dennis to much information. He will never learn how to do things on his own. If he was having a problem, I can see an explanation. That is why there is a Basic FCP forum. Professionals should know the process.
Steve Eisen
Board of Directors
