Activity Forums Apple Final Cut Pro Legacy Exporting time problem
  • Exporting time problem
    Posted by Rory Abel on December 21, 2007 at 4:27 pm
    Recently, when I attempt to export a project the time required to export it, which used to be a little under two minutes, climbs exponentially. After about ten or fifteen minutes it suddenly drops back and down and quickly finishes exporting. I haven’t changed anything in the project or any of my FCP settings. Has anyone else experienced this or know what might be causing it?
    Ryan Mast replied 18 years, 8 months ago 2 Members · 1 Reply
  • Ryan Mast
    December 30, 2007 at 6:38 am
    Do you have unrendered video in your timeline? When you export a sequence that has sections of unrendered video, it has to render those sections while writing to the QuickTime file. That’s likely why it slows down occasionally.
    Not really a fix for that, besides rendering before you export, but the overall time required is equivalent.
    Is that the case? If not, then it might be media that’s on a slow hard drive.
